key fob programming
Morning all. I’ve obtained a key fob from an 02 reg nb at my local breakers. Was wondering  if it could be programmed  to operate  the doors and boot on my 2.5. Mine didn’t come with a fob. Cheers
Taken from MX5-Scotland:
How to reprogram your remote key fob
My key fob stopped working, I did the obvious and changed the battery. Still no luck. In the end I got the key fob to work by following these simple steps. It had taken me ages to find out how to do this on the internet and to be honest it was not as clear as my instructions below. So I've posted my instructions on this good forum for the benefit of others.... (if a moderator is able to make this a sticky in the relevent place, I would appreciate it)....
1). Keep drivers door open.
2). Insert key into ignition
3). Turn the ignition on. To the point the dashboard lights up but not as far turning the ignition to the point of starting the engne.
4) Turn ignition off when red light extinguishes.
5). Turn the ignition on a second time to the point the dashboard lights up but not as far as starting the engne.
6). Turn ignition off again.
7). Turn the ignition on a third ime to the point the dashboard lights up but not as far as starting the engne.
8-). Turn the ignition off for a third time.
9). Rember keeping the drivers door open? Well, look on the car body next to the drivers seat, at hip level, for a small black button. It's near the sill. (One of the buttons functions is to turn the interior light on and off when you open the drivers door) Well, press this button.
10). Press this button again for a second time.
11). And again for a third time.
12). I think I could hear the door locks motoring at this point.
13) Press any button on your key fob.
14) Press the same key fob button again.
15). I think I heard more door lock noises.
16) Key fob reprogramming? ..... Done.
Hope it works for you.
John
Thanks for the quick reply. Does it matter that the fob was previously  programmed to another car?would my car accept a fob if it didn’t originally  come with one??
