My and the wife will be embarking on an 8 day drive through europe later this year, so i’m looking to knock up a wind deflector.
In all fairness, i don’t think the built in one is bad, and for the amount of miles we normally do, it’s sufficient.
However, driving for lengthy periods might take it’s toll.
As it’s unlikely to get much use after we get back, i don’t wish to fix anything permanent, or stat drilling holes in any trim and i’m not keen on spending upwards of £100 for something that will see little use.
Has anyone seen anything or maybe manufactured anything that can be clipped in easily.
if you are as tall as i am & you have both seats right back to the bulkhead, how about just a plain piece of perspex (top edge nicely round sanded) the whole width of the seats & as high/low as you want jamned betwix headrest & roll bar. or if you have the seats forward, use a couple of bungy straps. it’s only temporary so who cares what it looks like (that’ll upset the style purists )
actually having just thought of that, I might try it myself (with a piece of cardboard first); how hard can it be?
Have a 1992 Eunos but the one I have made could be adapted for your car. It is made out of a Childs Sun Blocker the mesh type for the windows of a car just make shure you get one with a large panel for the rear window they were found at Argos for a fiver four years ago,
I still reckon it’s a goer as some people have done it already. Learning from your experience I am going to look for some good quality plastic & try it.
We have done a couple of long trips around Europe over the last two years in a Mk3 with a standard windblocker and can’t say that we noticed any issues. A bigger problem may be spending all day in the sun with the roof down. My top tip is to wear a polo shirt or similar with a collar so that you can turn up the collar to protect your neck if necessary. Looks cool too
As RichardN says, the breeze can be most welcome at times. Also the factory windblocker is aerodynamically designed and, in my experience, some after market ones can be noisy or flap about in the wind.
