- My model of MX-5 is: Mk4
- I’m based near: __Beverley
- I’m looking for technical help or recommendations on: __Knocking on big bumbs at rear of car. I have spent money at a garage with no luck finding the cause. All rear suspention components look ok and has passed mot
It is most likely the spherical bearings on the rear suspension. 2 each side and easily replaced at a reasonable cost. Contact MechanicalDesigner for advice and a solution.
Apologies if this is a silly question, but have you checked for anything loose and heavyish in your boot, like the little tool pack that often sits in the right rear space behind the boot carpet? I speak from experience
(assuming you’ve ruled out the spherical bearings referred to above)
And read this Checking ND rear suspension bushes - Technical Area / Steering & Suspension - MX-5 Owners Club Forum
Try undoing one of the anti roll bar drop link nuts and then rock the anti roll bar. If you hear a clonk, one of the drop link ball joints is worn, difficult to spot when the car is either or on the ground or the wheels are in the air as both conditions put load into the ball joint so take up the slack. If one ball joint is worn best replace both drop links.
