Larini exhaust - DIY fit?
Hi,
I have a 1999 MK2 MX5 1.6i and the full exhaust needs changing as the flangle is fooked. I can salvage the CAT, which is a plus. I am planning on buying a stainless steel exhaust, probably a Larini back box and mid-section. Is this a DIY fit? I am pretty handy having worked on MX bikes my whole life, but wanted to ask those that knew (probably better…)
My insurance company want £45 more per year for this mod. Does this sound reasonable? My car is a Japanese import so I seem to get stung whatever I do…
Thanks,
James.
Hi
James I fitted a Larini exhaust with a mid pipe a few weeks back, it took me about 2 hours all in, that was with a cat that was a pig to get off.
<?xml:namespace prefix = o />  I had to re-stud the cat once it was off. It was all done in the garage with the car on axle stands.   O and it sounds spot on.      Roger
I asked my local garage to fit one on my MK3. Was glad I did as bolts on old one (18 months old) were VERY tight.
I am insured with AON - they did not require any increase even though there is a small power gain. The sound is terrific!
I guess that answers my question from the other thread lol
Thanks for the help. I will give it a go if I can get the bolts undone :wink:
My car is a bit older than yours. I had my IL Motorsport system fitted by a garage.
Glad I did as I stayed and watched and getting the cat off looked like a proper nightmare, The studs took loads of heat and still snapped.
You might be luckier as your car is younger.
<!–[if gte mso 10]>
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
<![endif]–>
Use
lots of WD40 (other penetrating fluids are available)<o:p></o:p>
 Why does that happen.
