Ummh, a bit puzzled. When Tim fitted the roll bars he noticed that the rear corners of the parcel shelf were wet.
This evening in the rain i have pulled the poppers around the carpet and there is water leaking over the top of the bolt rail.
The hood is mohair and has in effect an outer and rear panel which supports the screen.
I can’t see any sign of wet below the rail and it does seems to be coming over the top of the steel ring which bolts in.
Any thoughts?
