LED Strip Boot Light Replacement for ND
£27 including UK P&P.
Fits All MX-5 Mk4 ND 2015 onward models.
Soft top and RF models.
Easy installation.
No cutting into wiring.
Everything you need is in the kit. Bright white LED strip, adapter to replace existing boot light bulb, cleaning wipe and full instructions. Will take around fifteen minutes to fit with no tools required.
The standard boot light is badly positioned and provides little light and only on the left hand side of the boot. This kit replaces that bulb with a bright white LED strip under the lip at the rear of the boot. Much better lighting effect as you can see in the picture. The switch on the original boot light now turns the LED strip on and off rather than the bulb.
Any questions, please ask.
You can purchase via my eBay listing here -
