- My model of MX-5 is: NÇ
- I’m based near: Bristol
- I’m looking for technical help or recommendations on: Jump starters
Hi MX5ers
Just wondering if anyone has effectively used a lithium ion powered jump starter on their NC?
The reason I ask is because I have one but my MX5 doesn’t seem interested.
I bought a Halfords lithium ion powered jump starter for the Mrs’s 1.6L hatchback because her car was to be left at Heathrow long stay parking for a fortnight. Its an old car and though the battery is good, there’s a small power draw going on somewhere.
Sure enough, after touching down from our holiday the battery was completely dead.
This little jump starter thing worked a treat. I followed the instructions, she fired up straight away and the jump starter power was depleted by 25% so I left it charging from the cigarette socket in our journey home.
Once home, I knew that my MX5 would be dead because it also has a power draw. I think it’s the Bluetooth module which I ignored when I replaced the Bose CD changer with a double din android unit.
The battery was indeed dead.
I eagerly connected up the jump starter thing which had over 75% power, but it didn’t work
The engine did not turn but I could hear a clicking, presumably the starter solenoid.
So I then used jumper leads and her car then started my MX5 straight away.
Out came the battery charger and the next day she started fine.
Why does this unit start an Astra but not an MX5?
I bought one listed as capable of starting engines up to 2L, but when I got home from Halfords with my click and collect item it turned out they’d given me the next one up, which starts engines up to 3L. So it should have the cranking power to turn my 2L NC.
Am I missing something specific to the NC’s electrics?
Since then I just carry a 10mm spanner in the car and disconnect the battery negative lead if my MX5 is to be left anywhere long term, so I have a workaround, but if anyone knows why my MX5 refuses a portable jump start please let me know.
