Here’s the 1.6 Engine
And here is the 1.8
And here is an Auto, highlighted in the red square is the transmission dipstick
Oil level check for Auto
Make sure your engines warm and you’ve been through all the gears. The engine must be running while you check the level. Also have a sniff, if it smells burnt or looks black get the tranny oil changed
ENGINE NUMBER LOCATION
On a Mk1 1.6 the engine number is here, the top picture is just to show the general area
On a Mk1 1.8 the engine number is in a similar position on the exhaust side
