Locking wheel nuts
Can anyone recommend any? Mine are all messy and rusty so need to replace.
The McGard with the ring that turns is very good but you have to keep wax or oil on them to keep them looking good.
Thay are good due to being quite hard to get passed and so you should keep the wheels were you want them…
Thanks for that!
Don’t suppose you can tell which one they are from here can you? Not sure which I need.
here!
Mazda list two different McGuard wheel nuts; there is an open ended version that is equivalent to McGard 24012 (Mazda part number T001-V3-860G)
Good value at £16 a set. Mazda also list, special order from Japan, a different open ended lock nut which works with BBS wheels:
These are £15 a set.
And there is also a closed McGard set in a Mazda box, for £39. Buy online from
http://www.mazda-accessories.com/acatalog/Mazda_MX5__NA_NB__Alloy_Wheels.html
