- My model of MX-5 is: 2004 Mk2.5 with ABS
- I’m based near: Ashford
- I’m looking for technical help or recommendations on: Long brake pedal travel.
I’ve read 10’s of other forum posts about this sort of thing, but couldn’t find anything matching the symptoms I’m seeing.
Immediately after bleeding the front brakes, the pedal will be hard on the first pump. All subsequent pumps quickly reduce travel until I’m stuck with heaps of travel, and then a hard pedal just before it reaches the floor. Pumping the pedal doesn’t regain any travel, nor does leaving it for half and hour.
All corners bleed ok. The rears retain the reduced travel, so take forever to pump fluid through. The fronts appear to regain pedal travel as they’re bled, so after a couple of pumps can start to really shift fluid through them like I’d expect them to.
When bleeding I’ve had the hand brake on and off (doesn’t seem to make a difference), and the discs are held on with 2 nuts, so can’t move.
For some context, the car’s been up on axel stands since around April last year, and for maybe 3-4 of those months, the braking system’s been completely to bits off the car, and empty of fluid. When reassembled, the rear calipers were new, the front calipers have been cleaned off, sliders greased, and had seals replaced. Rear lines have been replaced, front lines are still the old ones.
The whole thing was bled from empty. I started by pulling fluid through from the reserviour with a syringe on the caliper (pulling the syringe to suck fluid into the syringe from the reserviour). Once there was something in each caliper, I switched to pumping fluid through with the brake pedal. There are no bubbles, and there must’ve been about 500ml of fluid through each caliper at this point, so I’m hoping that there isn’t some air that’s still hiding in the lines.
When that failed, I did some reading and realised I hadn’t re-adjusted the rear caliper screw. Did this, then re-bled. No improvement seen.
After more reading, it turned out I should have bled the master cylinder outside of the car before refitting it. So I took it off and bled it in a vice. A little air came out, but nothing much at all. Blocking up the two pipe holes with fingers (with rubber gloves forming a seal) made it impossible to push the piston in by hand.
Refitted the MC, then re-bled each corner, going Rear Left, Rear Right, Front Right, Front Left, as previously done. About 500ml went through the system, so say at least 100ml per corner.
This gave no improvement either.
All I can think of now is that either I need to do even more bleeding, the master cylinder (what with it being dry for so long) has gone past the failing stage and has jumped straight to completely failed (although if that was the case, wouldn’t the bench bleed have shown something up?), or maybe some junk’s got into one of the brake pipes when everything was apart and is causing issues somehow.
