- My model of MX-5 is: __NC
- I’m based near: Halifax
- I’m looking for technical help or recommendations on: Low biting point of clutch
If you use the ‘search’ facility then loads of info and help comes up.
You need to adjust the pushrod at rear of the top of the clutch pedal
The pushrod is threaded and has a locknut on it.
Need to loosen the locknut and adjust the pushrod by turning it in the thread until you have 2 to 3mm or so of free play at the pushrod.
Made an enormous difference to my clutch.
Did you do this ?
