Hi folks, have a week off so time to do something on my Fives…I would like to lower the seating position on my NA, already did a foamectomy which helps but i was wondering; is it possible to mount the oem seat straight to the floor? Can’t find anything regarding this on the web which seems to be an answer on itself…same for specific lowering brackets ; nothing on the web.
no one… ?:
As said before ; serious doubts if it would work (hence the question). Aftermarket solutions are mostly even worse as for example the Cobra Clubman seat will sit you even higher than oem…not sure about their (Cobra) classic range…would they sit lower? Again, even with aftermarket seats i wouldn’t mind floor mounting them if necessary . Would just like to sit a bit lower (i’m 1,85 m tall).
You could make up a mounting rail using quarter inch stock steel, bolting to the stock locations, then bolt the seat to the rails.
The problem is, with the seat attached to the rails, how you get to the 14mm bolts to fit. The fronts will be fine, the rears might be impossible to reach, assuming you mount the seat “all the way back”. You could weld a captive nut to the rails, open up the thread for the rear bolts, and put a bolt through the floorpan into the rail from underneath.
Track Dog’s Low seat mount, which won’t fit the stock seats, needs the rear mounts cutting out to gain 3/4".
Thx guys, usefull info here and…as i expected a confirmation of wat i thoughtought; Grass roots solution is “involving” , R theory is for aftermarket seats but i believe it would work for oem (mounting holes for Sparco seats are “close” to the oem dimensions) but issue here is that you’re not using the dip between the floorpan reinforcements meaning the hight drop will be about 2-3 cms maybe…third option is a no-go for Belgium as drilling trough the floorpan is a no-go for our TC (mot). I might have a chat with a welder and see what’s possible but fixing the rear bolts might remain the game-breaker. Thanks anyway for your posts.
The Elise seats sound like a good option as they’re not to racy/extreme to my taste and suit the 5 nicely (as a matter of fact they might be my first choice). Point is ; they’re expensive (new) and hard to find secondhand. They’re also easy to adapt on the oem sliders. Found a company who does great retrims on Elise seats for if the used seats would be in the need of that
; https://allonwhite.co.uk/ .
