lowering the hood troubles
when i try to lower my roof it doesnt go down very easily i always have to jiggle it and finally it will sink all the way down
its a NBFL and i assume its an original roof and window
so am i doing it wrong
my NBFL can be a bit like that if its quite cold, you will find when the temp is higher it will drop down fine…  The glass window seems to get a bit stuck, presumable because the vinyl being cold and therefore stiffer will not let it settle flat properly.  As you say, gently jiggling it will get it down…
my hood isnt vinyl though
i cant see where its catching or sticking either :s
