Lubrication of roof mechanism.
I’ve done a few searches but am unable to find any information on what sort of lubrication (if any) is needed on the electric roof and its workings.
It’s a MK3.75 car.
Thanks…
Hi Steve, I just used common sense and have oiled or greased all pivot points on the frames/gears/pivot points. Spray grease and ordinary multi grade oil Is what I used. I’ve also treated the seals with some ptfe type spray that the Audi service guys left in the wife’s car!  Have a start here though, might be of some help.
https://forum.miata.net/vb/showthread.php?t=337071
As Barrie says all pivots, I use Motor Bike Chain Spray sticks like s–t to a blanket, also use it on all door hinges, see you morrow Baz??, cheers Rob.
Hi Rob, yes I’ll be there bright n early  I’ll be halfway there at 04.30 as I’m dropping Mum in Law at Manchester airport. Then back home to set off at 07.00 for the meet!
Gosh Baz are you still buying those one way tickets cheap , does the lady have a hair scarf she does know the roof down rule . Dont talk to me about Audi,s had my bro round here today his A4  v6 Cabby for a window regulator change, oh joy, good old youtube,Rob.
