Does anyone have access to the Mazda coding/diganostic system M-MDS? I am looking to get some help with my MX5 ND which needs this tool
Chris
Chris
What are you wanting to do?
I have seen in here that you can turn on the High Beam Control which makes sense as the car already has the camera for the Lane departure warning
Was hoping I could do it and post about it as I haven’t seen anyone who has done that yet on a car that didn’t have it from new!
I don’t think that means that you can turn it on if it’s not specced from the factory with it. That’s just saying that the function can be turned on or off either using M-MDS or without using M-MDS (using the centre display). Has your car got the centre display?
Its not an option on my centre display currently, but I am curious to see if it can be enabled as the cars that have it have the same headlights, and camera in the windscreen and would be quite an easy win for most of us who have the same set up!
Yes, would be an interesting exercise to try it. Does your car have AFS?
Yep it has AFS, and I can see the light for the auto high beam in the cluster it just doesn’t illuminate! I am quite confident Mazda just disable the High beam control in this tool but need someone with access to I can check and share ![]()
Might be worth stating where you live.
Very true! Basingstoke
Someone who visits this forum has downloaded software for coding keys I believe. Could that same software allow access to other programmable parameters I wonder.
Might be worth searching some key coding topics. The name Forescan rings a bell (no puns intended).
