I’m looking for technical help or recommendations on: automatic shifter
So the shifter on my 93 mark one automatic is a bit loose, it moves from left to right a fair bit, I have had a look inside and it seems ok and it does shift ok, is this normal ??
Ok not sure if this applies to an mx had this on an early Toyota I owned there is a plastic Bush that over time and wear who takes the centre the car apart to grease a bit under the dash Did get another from Toyota at don’t know the size . Maybe someone else knows it
MX5 Parts apparently sell them. Not expensive ( even from them)
Part No. S.I. 3189. Need 2…about a fiver each or summat.
If for any reason you need a new shifter, Andrew at Autolink in Dumfries has mine.
He’s just done a Manual into my '93 auto and might have the bits.
It is odd changing gear in a car I’ve had 15 years…but it’s fun.
Getting bits for these old Auto’s eg sensors etc is not fun however.
As an aside, I would advise inspecting the external pressure pipes on the transmission for rot.
Clean them off, and get some “stuff” on them but avoid leccy connections.
Don’t ask me why I know.
Yes.
Multiple issues with bad garage workmanship pretty much ruined 2 trannies.
Cost me a lot of money. Too long a story and I’d rather not detail it in public tbh.
Got hissed off and handed my car over to “our Andrew” in Dumfries to convert.
What he found they’d done…was a bit of a shocker.
It’s a nice snick snicker 5 speeder now…Im happy.
Job jobbed.
