Wow many items. Not got a
6 but a fair experience with modern diesel. So here is my take.<o:p></o:p>
Lets try and take them one at a time, but I
would say your sister has made a number of mistakes in this so making her
situation a bit more tricky than it should be, but I doubt in a short time that
one top up of @ 1 Ltr over a short time would kill the engine. So I think you
need to build a better case for the defence and make the lease company justify
their assertion.<o:p></o:p>
When was the last time she checked the oil
level, if you can claim that the oil level has fallen rapidly then that is an
issue to be addressed prior to any discussion about the top up oil. If by
oil light you mean the low oil pressure light, then by the time the oil light
comes on you are in trouble. If she regularly
checked the oil level and can say it dropped suddenly in a journey then a
failure caused the issue. If not then is it negligence on her part? Is she
certain the oil level was at or above the minimum or was it at a lower level? This
is vital, and as she added more oil they will have a good idea (unless it is
burning/leaking oil like fury)<o:p></o:p>
If that was caused by a
low quantity of oil then their argument might be more correctly that by failing
to check the oil level she failed to follow the recommendations and normal care
expected. <o:p></o:p>
If she drove it along
while the oil pressure light was flickering then she has taken a bad situation
and made it worse. Low oil pressure light = stop now or live with the
consequences. That quite fairly could wreck a number of parts of the modern
turbo diesel, as well as the normal parts of the engine you have the turbo
reliant on a good supply of oil for cooling as well as lubrication. Driving a
few miles with the oil pressure light on is very bad news. And if the light
went off after a top up then I suspect it was well below the minimum level. <o:p></o:p>
So defence case one,
(check that this is true first) assert that the oil level was monitored regularly
and was significantly above the minimum level at a recent check. Does the car
have a low oil level check or warning feature/lamp? If yes then site this in
your defence and ask then to check the ECU fault log. Also assert that at no
time the vehicle had less than the minimum level. Also point out the vehicle
only covered “x” miles so the impact of the oil is a question to be answered. A
fair offer would be to pay for an oil flush and the normal oil change service
but not the rest of the repair. <o:p></o:p>
Regarding the engine failure, what specifically has
failed on the engine, they should be specific about that, and next ask them to
justify why using the wrong type of oil on a short journey has caused the
problem. Give us some info and perhaps we can help. And again ask them for a
copy of the ECU fault code register and ask them if they can show event history
information and count. This gets them worried.<o:p></o:p>
To my knowledge (which is
not encyclopaedic on this) the issue of sulphur tends to be a long term item,
and it either relates to build up of long term deposits inside the engine or pollution
for example of catalytic devices.<o:p></o:p>
Has this engine problems
well yes, but it tends towards the opposite problem of the sump filling up and
there has been at least 1 recall. http://www.honestjohn.co.uk/forum/post/index.htm?t=77225
http://www.honestjohn.co.uk/carbycar/mazda/6-2008/?section=bad
If it is the older version of the car, pre 2008
model then there are two common failures, 1 the oil pump leading to @ £6,000
re-build of engine and the flickering oil pressure light could line up with
this. And the fuel injection pump seizing. http://www.honestjohn.co.uk/forum/post/index.htm?t=57098
So I would sit down have an honest chat with her
and decide what to do next. If she is certain the oil level was never bellow
the minimum then I would go back on the attack and ask if it is the well
documented and reported problem with the pump.
And if it is wear that is the problem point out the
low oil pressure occurred prior to the use of new oil so the oil could not have
contributed to the failure.
