I’m looking for technical help or recommendations on: Why my steering feels like I’m not 100% in control sometimes when travelling at high speeds and why it feels like my car is gliding left and right when travelling at high speeds. Is this normal or do I need to have it looked at?
It could be several things, and a professional hands-on look is the quick way to resolving it.
Tyre prsssures could be too high
Steering alignment could be wrong
Components could be worn and have play, or even not done up properly. Lots of things here!
One of the things I was most impressed with is how planted the car feels at well into 3 figure speeds.
Check the obvious stuff as others have said, then get an alignment done if you don’t find anything.
Felt like it since i brought it around 5 weeks ago. Ill check all the obvious things in the morning, and ill check the old paper work to see if its had any work on it. It is 16 years old maybe it needs some tlc
Well worth getting the alignment checked, also possible that mismatching front and rear tyres can cause some odd sensations but definitely sounds like there’s something amiss
Of all the cars I’ve owned , only flyweight Sevens were more affected by tyre pressures. My daily driver Yeti feels more or less the same even with rather embarrassing underinflation , but the MX5 (ND in my case) feels bloody awful if the tyres aren’t just so … . If my right rear tyre is a few psi down (as it used to get with a very , very slow puncture ) I can accelerate to turn right and brake to turn right - but track straight as an arrow when all is as it should be.
A previous owner that cares so little as to fit those tyres in the first place probably doesn’t even know how to spell alignment.
We are talking a 4 wheel alignment as opposed to a tracking job at a backstreet garage.
4 reasonable new tyres and alignment will transform the car and the pleasure you get from it.
I usually take my everyday drivers to cheap backsteet garages for tyres, but i wont be taking my mx-5 there, ill possibly get someone to come out with a mobile service. what tyres would you recommend? I saw on a website that the Avon ZV7 were best.
When I got my 2011 NC back in August last year with 30,000 miles on it it was given an MOT, the selling garage failed it on back tyre tread and fitted two new ones. I later established these were Landsail (never heard of them). The handling was frightening on turn in to a corner. My pal suggesting putting the back tyres on the front and the front Pirellis on the back. Hey presto, that was the answer. The brand new Landsails were binned and new Pirellis all round…perfect. I also have a Caterham if that adds anything to the story. I did read an entertaining review of the Landsails which said succinctly “Dangerous in a straight line!”
A 4 wheel alignment on my 70,000 mile 2006 Mk3 was night and day.
I also had the Eibach 30mm lowering coils fitted which improved the look of the car as well as helping the handling. The top of tyre to wheel arch now looks good rather than ‘4x4’. This is a standard mod and many owners have had it done. I’ve had no problems with speed bumps and the like.
Your tyres are ZV5 and ZV7. The Zv7 was a later type.
It’s worth checking the age of your tyres too; There’ll be an oval on the tyre wall with the week and year of manufacture in it, e.g. 4420. Tyres harden up after a few years.
I’m running and am perfectly happy with Kumho PS71 tyres which many others recommend for the MX-5. This is a very good tyre at a budget price.
Cheers for your help, the front left says 4514, rear left says 3918, the rear right says 3918 and the front right says 4514. If my guess is correct that means 4th May 2014, so some new tyres are in order.
