Mazda NC 'Blue' Lowering Springs Part Number
It’s my understanding that Mazda supply two different versions on the ‘Blue’ NC lowering springs, one set for the ragtop and the other for the coupe?
Does anyone have the part number for the coupe version?
Thanks in advance,
Josh
Hi Josh, Mazda UK show 2 versions depending on year rather than model,
from 07/2005, 4100-77-774A
and from 10/2008, 4100-77-779
Start here with your year and click through to see,
http://www.mazda.co.uk/buying-owning/accessories/
Thank you Rich that site looks really useful
Josh
Springs for the coupe are different poundage due to wait of roof motors…the blue springs are still Eibachs…look on WIM website…if you fit the wrong ones the coupe will sit lower at the back then the front…
Hi Josh,
here are the specification of the springs (click on the pic to open a larger size - still a bit fuzzy, but one can read it :P):
And if you go to the I.L Motorsport page you can get the spec for the Eibach (non Mazda springs), which is the same spec, just different serial number.
Eibach Pro Kit Sport Spring Mk3,5: http://www.ilmotorsport.com/shop/get_documents.php5?docID=4676&art_no=NC0-0908&PHPSESSID=a6299dea562a887086b2b954f7c62689
Eibach Pro Kit Sport Spring Mk3:  http://www.ilmotorsport.com/shop/get_documents.php5?docID=1702&art_no=NC0-0904&PHPSESSID=a6299dea562a887086b2b954f7c62689
I.L.Motorsport 40/50mm Sports Springs:  http://www.ilmotorsport.com/shop/get_documents.php5?docID=4898&art_no=NC0-0903&PHPSESSID=a6299dea562a887086b2b954f7c62689
I would go for the …774, since they will offer the smallest drop. Had the …779 on my previous Mk3 and they where a bit to low. Unless you just get them for the look …
Hope this helps.
Cheers,
Adrian
