- My model of MX-5 is: 20th Anniversary NC2
- I’m based near: Sheffield
- I’m looking for technical help or recommendations on: Seat heater switch panel.
I’ve bought and fitted NC2 heated seats, also bought the correct switches.
I’m looking to get the panel with the aux input and 12v socket without the recess that mine has.
I’ve been advised the panel needs changing to enable the fitting of the switches.
I went to my local Mazda dealer at the weekend whilst being very helpful, said if I purchased the incorrect part no refund would be given as I’d ordered incorrectly.
Made a few enquiries and apparently the part number I need is NH5364470D checked Mazda part search online and the link below has brought this up
I’d be grateful if somebody with more knowledge than me could check to see if this is the part I need to swop out to fit the swiches into.
I’m aware I’ll also require the non recessed rubber mat.
Many thanks
Just looking for the part that the switches fit into, clinked on the link sent then clicked on the links below when opened.
It just says part not found.
Not sure what happen there, Try
https://partsouq.com/en/catalog/genuine/search?s=NH5364470D+&c=MAZDA2020&ssd=%24*KwG3g5L81rPZ18fXzNiQl-_729zCs7yxsKKNvvbww9fLz83Oi5yw2vTw9MXTytudgIq3vs7aqLH94rO2q8Xdt_zj9sPnoqWnt8S2u7MAAAAAJOQvMw%3D%3D%24&vid=1927005494&gid=&cid=2496&q=
Then click on the diagram,and then on the part. There are four options listed, two for cloth seats and two for leather seats.
Number |
Note |
There are several options available for your car, pick the correct one. |
NH52-64-470C |
A (NH52-64-470D) ; CLOTH B; - 081225$NC18** -200689 |
NH52-64-470D |
CLOTH B; EXC.25TH SV; 081225 -$NC18**200689- |
NH53-64-470C |
A (NH53-64-470D) ; LEATHER; - 081225$NC18** -200689 |
NH53-64-470D |
LEATHER; 081225 -$NC18**200689- |
Then you need to find out which side of the change over serial number you need to be.
Emailed my local Mazda dealer, just waiting for a reply. Should hopefully be sorted soon.
Thank you for your advice🙏
