- My model of MX-5 is: __NBFL 1.8 turbocharged
- I’m based near: __ Chelmsford
- I’m looking for technical help or recommendations on: __ misfire problem
Further to a previous post Ive made Im still having problems so thought I would create a more specific and detailed post in the hope that someone has any ideas.
I have a 1.8 VVTi with 35k on the clock running a turbo with an emerald ECU professionally tuned. Has run well for years.
It has had an occasional misfire that would be felt during steady cruising, but never under acceleration and always performed strongly. I couldn’t identify the source of the misfire and presumed ultimately it would evolve to the point that it might be easier to trace or Id flush it out on a rolling road…
This winter I upgraded my exhaust and manifold to a 3 inch set up up from a 2.5 inch and also renewed my cambelt and water pump and fitted a fluidamper uprated harmonic damper.
After this the car started, but takes a few goes, before it doesn’t stall. It holds a steady idle and sounds perfect. Out on the road it accelerates strongly and smoothly, no issues apparent. But when cruising the misfire seems more persistent.
I downloaded the Emerald software and plugged my laptop into the ECU, more as an experiment in case I had to take it anywhere as Im not competent to actually tune it myself, however it allowed me to view the AFR and I noticed that at a constant throttle say 2500rpm it will drop to 2000rpm every other second or so and the AFR shoots up to 20. It doesn’t do this at start up, only after a few minutes running. This is a pain because Ive given the engine bay lots of looking over, found a loose earth, and a plug that wasn’t fully home and thought that I had cured the problem only for the surging to start again. after a minute of running again.
Ive had my spark plugs (NGK BKR7s) out and found them all looking quite black and smelling of fuel. Normally the plugs look the perfect colour when Ive had them out or changed them. To my mind, the fact that all the plugs look the same rules out a dodgy plug, spark lead or Coil on plug.
Im sure that the cambelt is in the right place as I turned the engine a number of times to double check all the marks lined up and like I say it sounds sweet at idle and accelerates great.
I am wondering if I could have introduced a problem with the replacement harmonic damper. I run a 36-1 trigger wheel which I presumed because of the keyway could only go on on one way, but if this was wrong, would it cause these symptoms? Really Im hoping that this is a development of the earlier issue
If not does anyone have any other ideas?
Ive got a new crank position sensor on order as the existing one looks old but otherwise I m at a loss now.
Cheers
Ben
PS Emerald, my goto tuner are booked up for months and I was hoping to get this fixed before then.
