Hi all. Firstly apologies if this is in the wrong section.
I have installed a new Mishimoto radiator along with a new fan shroud. The issue I have is in wiring up the fans.
The OEM fan I removed was a single unit with the original connection however the new fans (they come as a pair) have individual wiring with bullet connections which means I will have to splice into the original wire.
My question is, do I just connect both fans to the original wire from the original single fan?
Im fairly confident in most things mechanical however where wiring involving relays etc are concerned, I’m a bit stupid.
