- My model of MX-5 is: nb 1998 1.8
- I’m based near: swindon
- I’m looking for technical help or recommendations on: fuses
Just had a look in my fuse box and discovered that the st.sig fuse is not there and i was wondering if it should be there i have had a look for an aftermarket ecu and it has the standard ecu from manufacturing
Where is the fuse located? I can’t see it listed in the UK workshop manual wiring diagram so maybe it’s for other markets. Cruise control maybe, STop SIGnal?
Its the fuse box inside the car i have since had the chance to have a look at a couple of other cars that are the same model and they also dont have this fuse so i believe i have my answer thanks forctge help
