So… today marks 2 months of my mk2.5 being off the road and unable to start. Let me take you back to beginning…
Had it as my daily driver for about 2 years, always been a trouble free car.
One day I wake up decide to head off down the motorway to Donny to meet some mates. She starts up first time as usual no problem.
After about 15 mins of driving im doing 70 on the m18 when i notice shes died and im coasting. So i pull over to the hard shoulder and try starting her again. Nothing.
Cranks but just wont catch. I call the recovery guy out who proceeds to try starting her up and she fires up no problem, runs for about 30 seconds and then dies again and wont start back up.
After being recovered back home he diagnosed it as undoubtedly the fuel pump. Now… I don’t recall ever listening myself to check if I could here the click and the hum of a working pump… I was too eager to replace it, wanting my car back so I could get to work. I decide to buy a working used pump with the rest of the system attached so I could just drop it straight in. So after a quick swap… nothing. Still not firing. 100% this pump is working though, I hear the hum and click and removing a fuel line and trying to start her up results in a gush of fuel spewing out.
Since then I’ve checked for spark (all good) all the spark plugs look as they should. I’ve replaced the crank angle sensor after reading that might be the problem (Had the toothed wheel replaced previously after someone bent a tooth off when it was being serviced) I’ve replaced the cam angle sensor, again after reading that might be the issue.
Had a second mechanic out who found a MAF sensor error code and advised either vacuum leak, fuel starvation, or collapsed cat.
I replaced the MAF unit after that and although I didnt remove the exhaust i tapped the cat with a hammer to try and diagnose if there was any loose material in there and I just dont think there is. As far as a vacuum leak I’m just not sure where or how? It just seems to me like its a fuel issue.
Thing I’ve discovered that work… if I remove the air filter (got an aftermarket induction kit) and cover the intake with a bit of tape just right so there was a little bit of air still getting in. She’d fire up and run, quite badly but she runs. Also, if I remove the spark plugs and pour a tiny amount of fuel in each cylinder she starts up and runs for about 15 seconds.
Help me community! you’re my only hope!
