Hi all, the use of my clutch had been getting worse for a while. The bite point went to the floor and changing gear was hard. You could pump a few times and it would spring back to life though!
It eventually died completely so i rebuilt the master cyclinder and bled the system. Worked fine for a day but now im experiencing the same issue. No where near as bad mind, but its still not working right.
Symptoms are:
Varying bite point
No leaks
Sometimes cant select a gear at all
Gets better if you pump a few times
Both master cylinder and slave are new.
Thanks all
