- My model of MX-5 is: __
- I’m based near: __
- I’m looking for technical help or recommendations on: __battery
Hi does an 063 battery fit on a eunos 1.6 ok ?
Hi.
I believe this was my recent purchase and it works fine
Ant
063 battery size is 210L x 175W x 175H
Mk1 battery size is 235L x 125W x 160H
If you have a plastic tray for the battery then you will have to use something else. I used a piece of ply covered in some rubber to make it non slip when I used a non MX5 battery. I had to adapt the battery tie-down as the original didn’t fit as the battery was wider.
Not recommended as it is a wet battery in an enclosed space. The standard battery is vented to the outside of the boot. Lots of info on the site about this or here
I used this to fit a 063 battery in my Eunos:
https://www.mx5parts.co.uk/battery-fitting-mk1-p-3676.html
Thanks for your reply’s
