i purchased some replacement rubbers from CES as I expected the original to be worn, both the replacement and new rubbers don’t seem to make a difference.
After market hangers are frequently no good; best stick to OE Mazda. The exhaust is banging on the diff because the hangers aren’t really stetching. If you have a mixture of OE and pattern hangers, try swapping them around a bit.
Moss are correct; its premature to blame the exhaust before checking that the cheap rubber hangers are correct. Do that before following else’s advise that involves bending exhaust brackets. Try fitting the OE rubbers on the back box only, to see if that drops a bit to clear your diff.
As a 1989 car, there was never a rear subframe brace fitted, and without changing subframes, its not possible to fit the factory brace, so whatever you have is aftermarket. Its well known that many aftermarket braces foul aftermarket exhausts.
I fitted the exhaust myself, it’s jammed tight against the the diff, I can try different rubbers but I’d be surprised if they push it down with enough force?
I have a cobalt back box centre pipe and decat pipe with a 421 manifold and it’s a perfect fit I’m guessing you have a longer or shorter cat that is causing it to touch the diff
It’s a stainless decat pipe I’m not sure as to the make it could be a cobalt as it looks the same as the rest of the system which defo is I got the lot off ebay for a total of £66
And yes it does fit with a standard down pipe as I had to use mine to pass my mot last year as I was unable to get the lambda sensor out of the old pipe to fit it to the new one in time
You need to measure your cat and if you have the long one and it’s that that’s causing your back box to jam on ya diff then go for a short decat pipe or vice a versa if yours is a short cat
I too bought one of these Cobalt systems the last time they were on offer and a new stainless Cat. The Cat supplier went to great lengths to ensure that I was ordering the correct size which in the case of the Eunos is the shortest (375mm) if I remember correctly, telling me that all imports are fitted with this size. All fitted correctly and although the middle box is very close to the frame it does not touch, or rattle when driving.
i see where you’re coming from, but I bought the Mazda so I could do all these things myself, if I’m going to have a garage do it all, I may as well sell up and buy a new car with a warranty and service plan.
Specially for the sake of just adjusting a few things
