If it were me, genuine Mazda while they are still available. You’ll be kicking yourself in 5-6 years, when the cheap ILM hoses give up, and Mazda originals are scarce.
9-hose genuine Mazda hose set, 1.6, I priced up at £102 plus VAT (and before the usual discounts) from Autolinkuk, all in stock. I suspect Mazda counter prices won’t be far off (especially if you include postage). Bit more money than the £75 wanted for ILM’s unknown set (Chinese origin ? A lot of their parts are, and they might not even keep to the same supplier), but is it really unaffordable? Even if it cost more, I’d still opt for it. You’ve had hoses that have lasted 20-25 year thus far, and on a precautionary principle, want to change them out, for the next 20-25 years.
This is a steal:
https://treasurecoastmiata.com/i-22957651-90-93-new-oem-miata-complete-water-hose-kit.html
Can even get new clamps thrown in.
Never had to use a lubricant to fit a hose, but thinking about it, is there a reason not to use red grease? Need to find a use for the massive tub of it I picked up from a motor factors, other than the once in a while dabbing on brake caliper.
I am a big fan now of waterless coolant (Evans) after having the 1.8 converted to it. Took a bit to bleed it properly (maybe a difference viscosity to water+glycol). I like the idea of improved engine life due to absence of micro-cavitation, and piece of mind in having no pressurisation; nada, nothing. I can pop the radiator cap off (if I wanted to), engine redders, no loss of coolant. Coolant loss due to failed radiator cap thing of the past. Engine corrosion, thing of the past. Slimey crap on the inside of the hoses, thing of the past. Increased radiator life (stress fractures due to pressurisation?) Needs a bit of up front investment though; best part of £100 to do (cost can be reduced if two cars do it, as the flushing agent to remove water can be reused).
As for evidence of “similarly reliable products”, the only alternative that in the MX5 has any kind of similar 20 year+ track record are Samco silicone hoses; I have a recollection people were fitting these to 5 year old cars back in 1996. The Kevlar reinforced hoses have been around, say, 10-12 years, and as you indicate, have a patchy record. ILM hoses. Who knows. They don’t make the hoses themselves. They’ve invented “Genuine IL Motorsport” branding (ie. there are fake IL Motorsport parts). I notice where they are using some top German supplier, they can be quick to crow about that. So in the absence of that, I’m assuming China is the sourcing. China per se is not an issue; changing suppliers (and spec) is.
So OE Mazda.
