The lights on my mk 1 pop up and down with no problems at all but when i turn the lights on sometimes both lights will come on, then i will turn them off and then when i turn them back on only one will light up, then off and on again and the other one will light up and the other light will go out again. any suggestions? Thanks
Trace any electrical joints in the headlamp area and you will find that some if not all will have corrosion on them. Cut off the corroded bits and rejoin them. This should fix your intermittent lighting problems.
Thanks will have a look and see what i can find
