I would seriously consider buying some stainless wire in the correct gauge and making replacements in the usual way; heat to bright orange and bend around a former and then trim the ends to size. Maybe a bit more heating and cooling to get the right amount of springiness.
I managed to find this online, but as I feared you can only get a lock cylinder complete by the looks of it.
I feel your pain about the tiny spring as I had to replace one on a lock in my car, in fact it was one of the first jobs I did.
Don’t do what I did though. After getting a spring from another MX5 lock cylinder and seeing a little corrosion on it from the barrel I decided to give it a quick clean with a wire brush on a Dremel before fitting it in my lock. Within 5 seconds it had shot out of the pliers I was holding it with and disappeared somewhere in the garage. I’ll never see that again I thought, and sure enough after a quick search I couldn’t see it. However… the following day I saw something on the ground. It was the spring!!! It’s still got that corrosion on it, where’s the Dremel? Ping, out of the pliers again and this time it was gone for good. I remember saying something like ‘Clucking Bell’ or similar.
I think I ended up using one from another door lock I had in the garage at the time, possibly from a SD3 type Rover 200 series. It would be easier to find a similar part from a common door lock than to make one.
Or just buy a bag of torsion springs, and cut to length. I have an idea that a bit of wire wrapped around a nail, even stuck in the overn, won’t be much of a spring, and you’ll win no fans when someone gets a key jammed in a repaired barrel.
The springs used to be available for BA 323F as a separate part on a TSB because the little flap used to break (plastic on that model). I’ll try and dig out the part number for you. Not sure if they are identical or not though.
These springs are really small - a tight fitting arbor = 1.5mm drill bit. I am going to use the slightly looser fitting smallest precision screwdriver shaft as I think 316 stainless will expand slightly with cooking.
On that note any ideas on cooking the springs without stinking the kitchen out? Hoping i may get away with an hour at 450F with the springs wrapped in tin foil.
Part number from Mazda is B25D-58-49X (for a 323). I don’t know how much it is or if it’s still available even. You’ll need to try the number at a Mazda dealer or MX5parts.co.uk maybe.
