Does anyone have a tool for removing the gearbox level plug on a MK1 MX 5 NA?
A 14mm set spanner fits but mine is so tight its likely to round off the corners of the plug using this type of spanner. I even asked my garage at MOT time and they couldn’t get it undone without risk of damage.
I feel your pain, when I replaced the gearbox oil on mine last year I struggled to move it. A couple of years before I’d checked the oil level and hadn’t overtightened it, I’m guessing with the plug having a tapered thread it had stuck.
I finally removed it with an open ended 14mm spanner with a length if tubing over it to add leverage. Not best practice but needs must.
When I looked for a proper tool for the job (female 4-point socket, 14mm across flats) there wasn’t much choice. In Japan I found a couple of places listing a tool for a Datsun gearbox plug that would’ve been perfect, cost ruled them out with postage though.
These were the only places I found that listed a socket;
I could not fine one either but surely there is a bespoke tool available for this? Guess it is something the club would have and lend out if it was readily available.
Important with the 5 speed box to make sure that the fill plug can be undone before committing yourself to draining oil.
I changed the oil in situ on both our cars last year and yes definitely needed doing. I was very lucky to get away with using my heavy duty 15 inch adjustable spanner. Placed the plugs as far into the spanner as possible, wiggled and tightened a few times and then went for it. Having read up on this job breaking gearboxes I consider myself lucky. Glad that this is a job I will not need to do again for a while.
Developed a very effective way of filling the gearboxes with oil - will write up at some time.
Great bit of fabrication Drumtockty. Brings back memories of my Dad who used to be in the farm machinery repairs business. If he needed a special tool he just made it as well. Alas he is in a home now, virtually blind, deaf and immobile which is very frustrating for him but he still recounts many stories like this from his working past.
