Mk1 NA Eunos door cards?
Does anyone have a source for Mk1 Eunos door cards and door pockets?
i can find sellers of MX-5 door cards and arm rests but not for the Eunos.
Or if anyone has the part numbers? Perhaps I can try search using those!
As far as I am aware the door cards are the same for the UK NA and the Eunos, I have a Eunos and have replaced them with door cards from a UK car which fitted exactly the same.
I have since made my own door cards with 4mm MDF and covered them in black leather with orange diamond stitching to match my seats this was cut using the old UK door card as a template
The cards with pockets are specific to 1994/1995. Nothing to do with being a Eunos Roadster. That is why you are struggling to find them
Yours look great.
Mine don’t have the armrest but just have larger speaker grills, door handle pull and pockets.
They are like these but with ‘tear drop’ speaker surrounds.
Ah thanks Richard, that would make sense, mine is a 1994.
Is there a source for these? And for the pockets, etc?
Newton Commercial produce faithful replicas, for all years of Mk1:
https://newtoncomm.co.uk/collections/mazda-mx5-miata-eunos
93-95 short handle model:
https://newtoncomm.co.uk/collections/mazda-mx5-miata-eunos/products/mx5-miata-door-panels-pair-1993-onwards
For these cards, you need to transfer over the door top your self, easy job.
Cheers Saz - I stumbled across Newton after Richard mentioned these cards were two years only but still appreciate the link.
Now I just need to track down the interior handle and pocket.
Anyone have any ideas on where to find those? Or the part numbers?
Mine has these door cards and as far as I can see the pocket is part of the card, so would not have thought it was available separately.
Your friendly auction site has the handles
https://www.ebay.co.uk/itm/Mx5-Mk1-Na-Inside-Interior-Door-Handles/233269292817?hash=item364feeef11:g:VvMAAOSwl-ddEeVt
Good luck.
Dave
Thanks Dave.
I think my monitor brightness is too dark - after you said the pockets were on the cards, I looked closer and I think you’re right… they seem to be on the Newton cards.
Ideally, I’d like new handles… if anyone knows a source, I’d appreciate it.
Mazda. But why do you need new handles? Yours missing?
MX5 parts sell the long handles but not the short, perhaps some of the other parts suppliers may hold stock if you are lucky. I presume yours are damaged or missing, the ones on eBay look in good condition and the car is almost 25 years old afterall.
Mazda may be able to supply at a price, but when I was looking for front brake shields recently they no longer supply them for the Mk1.
Dave
Yes, as Dave has said, mine are a bit ratty.
If I change the cards, I think the handles will stick out like a sore thumb. I’m going to work on them this weekend but for the sake of a few £s, replacing them seems the best option.
Look up techniques to improve plastic trim using a heat gun or hair dryer.
An alternative to the plastic door pulls are leather door pulls. Several suppliers. eg
https://www.jassperformance.com/shop/mazda-mx5/Interior
Autlinkuk also supplies the Jass parts.
Mazda prices are not that bad, and stock levels depend on demand.
The right hand grip is N026-69-D70 and left is N026-69-D90
Checking US suppliers, the right grip is still available, and on discount:
https://www.realmazdaparts.com/auto-parts/1995/mazda/miata/m-edition-trim/1-8l-l4-gas-engine/body-cat/interior-trim-scat
But the left is discontinued. Your left grip should be in good order still, if your car is RHD.
Autolinkuk has used parts:
https://www.autolinkmx5.com/door-pull-handle-mazda-mx-5-mk1-2-point-left-hand-black-lh-n02669d90-used-8102-p.asp
https://www.autolinkmx5.com/door-pull-handle-mazda-mx-5-mk1-2-point-right-hand-black-rh-n02669d70-used-8104-p.asp
Members of the MX5 Owners Club will enjoy an additional discount.
Mate, there’s a guy on another forum who is looking to sell a pair of door cards complete with everything on them. They look like Eunos S-Special type1 to me, and are just like the ones you are after. Let me know if you want me to send you a link.
That would be great; thank you
sent you a PM.
Recieved, thank you.
It is unfortunate that they have the tweeters in the door tops.
My goal is to return my LE car to very near stock and it didn’t come with a stereo, let alone seperate tweeters.
His price also seems… optimistic.
Which limited edition Eunos Roadster is this?
There weren’t many, and none didn’t come with a stereo, although studio shots might show that.
The available 93-95 limited/special editions with black door cars:
J-Limited II; tweeters fitted
RS-Limited Tweeters fitted
G-Limited; tweeters fitted
The other limited editions during this period, the Tokyo Limited and R-Limited, did not have black interiors.
Its not unknown for some importers to invent limited editions, to either justify an inflated price, or pass off a modified car as factory.
And the door tops seperate, easily.
RS
I was under the impression - perhaps wrongly - that there was no headunit fitted?
My plan is to put one of these in mine: https://www.classiccarstereo.co.uk/hidden-audio/hidden-bluetooth-amplifier/
…so the door speakers won’t be unused but from the photos I’ve found, there doesn’t seem to be tweeter in the door tops.
