Hi everyone
I have acquired some job lots which i would like to dispose of.
The list is below. I have not posted pictures because there are too many (over 80 items) but each iten has a description. It was an excel spreadsheet so i hope it come out ok
I have got pictures of most items so I can send by email if you let me know what your interested in.
I hope to be at Gaydon with this lot if I can get it all in the car. I will definitely bring any parts you want.
I will post or courier most things but postage cost will be extra - please ask. Thanks for looking
EDIT some parts now sold
Steve
MX5 Mk1 PARTS FOR SALE
Description No Condition £Each
1 Air filter box/housing assembly 1 Good / Used 15.00
2 Air filter intake (front of cam cover) 1 Good / Used 10.00
3 Ashtray light 1 Good / Used 5.00
4 B Pillar door seal - to Roadster plate 1 Good / Used 10.00
7 Battery bracket - boot floor 1 Good / Used 5.00
8 Battery clamp - upper 1 Good / Used 10.00
9 Belt - timing 1 Good / Used 5.00
10 Belt -Alternator or PAS pump 1 Good / Used 5.00
11 Boot clip - cable restraint - clips to NS light cluster 1 Good / Used 2.50
12 Boot closer torsion rod 1 Good / Used 10.00
13 Boot lock & release (no key) 1 Good / Used 5.00
15 Cable bonnet release - to ball end only 1 Good / Used 15.00
16 Cable bonnet release & complete lock mechanism 1 Good / Used 25.00
17 Cable -Fuel cap (orange) release (from centre console) 1 Good / Used 15.00
18 Cam cover bracket - oxygen sensor 1 Good / Used 5.00
19 Cam cover vent pipe - chrome 1 Needs rechrome 10.00
21 Carpet - Rear deck - Black 1 Good / Used 20.00
23 Carpet - Behind seats - Black 1 Good / Used 10.00
26 Coolant expansion tank (incl pipes to radiator) 1 Good / Used 15.00
27 Coolant hose - long 1 Good / Used 2.50
28 Coolant hose - short 2 Good / Used 2.50
29 Vent pipes connecting above chrome pipe 2 Good / Used 1.00
30 Cushion - rubber - Cone shape various sizes 4 Good / Used 2.50
31 Dashboard blanking covers - Oblong Black 12 Good / Used 1.00
32 Dashboard blanking covers - square Black 2 Good / Used 1.00
33 Dashboard crash pad - large 1 Minor crack repaired 15.00
34 Dashboard crash pad - small 1 Good / Used 10.00
35 Dashboard vents 8 Good / Used 1.00
36 Door lock actuator (Aftermarket/Mazda accessory) 2 Good / Used 15.00
38 Exhaust manifold gasket MG7309 1 New 5.00
39 Fog lamp lens - rear 1 Good / Used 2.50
42 Fuel filler pipe & overflow pipe incl fuel cap 1 Good / Used 10.00
44 Fuse box NO34 - engine compartment 1 Good / Used 30.00
45 Fuse box bracket- engine compartment 1 Good / Used 5.00
46 Fuse box NA10 - cabin 1 Good / Used 15.00
48 Grommet - Large in boot floor 2 Good / Used 1.00
49 Heatshield for crank angle sensor 1 Good / Used 5.00
50 Horn 2 Needs painting 15.00 or 25.00 the pair
51 Indicator/wiper stalk - N002 1 Good / Used 30.00
52 Interior courtesy light lamp door switch 1 Good / Used 5.00
53 Interor quarter panel - OS - black - 1 Good / Used 15.00
55 Oil filler cap 2 Good / Used 1.00
58 Radio aerial / antenna - screw in type 1 Good / Used 20.00
59 Rear shelf support for folded hood (with screw) 1 Good / Used 5.00
60 Seat belt attachment to tunnel - plate & spacer 2 Good / Used 2.00
61 Seat fixing bolt covers - black 6 Good / Used 2.50
62 Side indicator - wiring harness 2 Good / Used 2.00
63 Steering column inspection cover - Black 1 Good / Used 15.00
64 Steering column inspection cover with grommet - Tan 1 Good / Used 18.00
65 Steering wheel boss - Eternal flame 1 Good / Used 40.00
66 Switch - blanks 4 Fair / Used 3.00
67 Switch - hazard & headlight pop up 1 Good / Used 15.00
68 Switch - headlight level 1 Good / Used 10.00
69 Switch - instrument dimmer 1 Good / Used 15.00
70 Switch - power door mirror - 4 way 1 Good / Used 15.00
71 Switch - Rear fog light 1 Good / Used 10.00
73 Switch panel 1 Good / Used 8.00
74 Wheel arch liner - NSF 1 Good / Used 40.00
75 Wheel arch liner - OSF 1 Good / Used 40.00
76 Wheelnuts - Chrome 8 Good / Used 2.50
77 Windscreen side vertical trim - black 1 Good / Used 15.00
78 Windscreen side vertical trim - black 1 Damaged lower clip 2.00
79 Windscreen washer tank & pump 1 Good / Used 10.00
82 Wiper motor - Link to Splines 1 Good / Used 5.00
83 Wiper motor - Link to Splines 1 Good / Used 5.00
84 Wiper motor - NA10 (JDM import) 1 Good / Used 25.00
85 Wiper scuttle panel 1 Good / Used N/A
86 Wiper spline mounting bracket 2 Good / Used 5.00
