Anyone help with images, diagrams or suggestions how to wire the double switch?
Got the switch but no connector for the back of it, so can’t wire it up?
Any help welcome!
Any help welcome!
Got connector now but still need help in wiring up current single rear light switch and new front lights
It’s a complicated circuit, you really need the fog lamp relay to go with the switch. I can send you a PDF of the circuit if you send me your email address… Consider joining the club though
Thanks. Seen your diagram on another post but still couldn’t work out what wires from current single rear switch went where in the double switch. There’s one to the instrument panel to light the tell tale which seems to be missing from double switch, or does it then come from a new rear control unit? And where does the wire powering the front tell tale light on the switch come from? And how does it fit into working only with the headlights on?
finally, some offer advice on modifying the switch so rear one stays in like front one. This would mean if you switched ignition off, the light wouldn’t automatically switch off but be on when ignition comes back on?
email is garyjbirch at gmail dot com.
any help appreciated
Do you need a wiring diagram?
Yes please - especially need to know where current wires to single rear fog switch go into double.
thx
