Mk2.5 S-VT Spark Plugs
I want to change the spark plugs on my Mk2.5 S-VT while I’m doing an Oil change and check over,
If I use NGK I know I need BKR6E-11 plugs, but,
thinking either Iridium or 4 tip plugs, believe these are Bosch, but cannot find which ones of these are for my car.
Anybody got the plug numbers for these please and if they do indeed make the car run better.
Thanks everyone
IMHO.
 If you have 3 or 4 tips it still only does one spark
"Leccy takes the easiest route so if that electrode erodes then it uses the next one. The effect of this is that the plugs last longer.
Since normal plugs do 30k, unless you are planning huge milages then I can’t see the point.
I’d rather use a normal plug and change every 15k.
Paul G
Agreed Paul!
