Can anyone tell me what the thread is on the seat bolts? Appears to be M10, but an M10 nut won’t fit, so I presume the pitch is different (I want to put spacers in to improve driving position, so will need longer bolts).
TIA
TIA
From memory it’s M10 x 1.25.
It’s definitely metric fine, which is why a standard M10 nut wouldn’t fit, it would have a pitch of 1.5mm.
If you have a M8 bolt handy you can check the thread pitch against it as it will have a 1.25mm pitch.
Cheers mate - absolutely right M10 x 1.25 and 15mm length should anyone need that in future.
Will order longer replacements today
Many thanks
No problem, glad I could help.
