Mk2 clutch master cylinder bore size
Hi
Can anybody tell me the bore diameter of the clutch master cylinder on a Mk2, may be the same as a Mk1?!
The full cylinders will interchange so presume bores are same also
It’s fitted in a Westfield Kit car .
They supply a 0.7 inch master cylinder which gives the slave too much travel so we have to fit a pedal stop.
It also operates like a switch it’s so sharp, so I’m thinking of a smaller bore. Off the shelf these are 0.625" and 0.5" and wanted one to match the original.
Ian
