Hello, has anyone tried this?
No but post your results when you do.
It would be quite significantly a different diameter.
Don’t they also have problems clearing the front & rear wheel callipers ?, think it has been tried before.
And what do you do with the wheel you replace?
How does that go if ND is 5 stud & Mk2/Mk2.5 are 4 stud?
Or…am I missing some trick?
Yes Robin, you are missing trick.
The Mk3 had a 5 bolt wheel fixing.
The Mk4 went back to a 4 bolt wheel fixing.
Can someone explain to me why everything Mk4 ND I see is designed for 5 studs then?
They kicked off with 5, then at some time reverted to 4?
Hi Rob! Well the only reason I can think of is that the pr*ts in R+D didn’t do their job properly because my ND is definitely 4 studs and it’s an early one Aug 2015, and I don’t suppose it’s in any way a “one-off”!
PS: Of course it’s more likely that some pr*t in advertising just picked the wrong picture!
Mmmm…OK. Just wonder what Mx5Parts think they are doing then…plus a few others.
Unless…they just package off 4 stud versions of the same.
Really odd.
It’ll just be a generic photo for all versions (and quite possibly makes/models).
mx5parts will send you the correct version.
S
Generic photo’s maybe but then they are kind enough to supply spare wheel nuts!
“Also, unlike many alloy wheel suppliers, all ours come as a set of 4 complete with centre caps, 20 new wheel nuts, the required spiggot rings and carry a full 12 month manufacturers warranty.”
https://www.mx5parts.co.uk/dotz-kendo-alloys-black-mk4-p-3746.html
The ND Chassis shown at the March 2014 NewYork Motor Show around a year before the launch of the car had a four bolt wheel hub interface.
Yes, many wheel suppliers are renown for only selling wheels in threes!
coconino:
H1S VRB:It’ll just be a generic photo for all versions (and quite possibly makes/models).
S
Well Nick, at least you ended up with more than a man’s fair share of nuts.
NickD:
coconino:
S
Well you get 4 spare with every cut and paste posting on MK4 wheels when you by from MX-5 Parts.
