mk3 Bilstein rear shock dust covers?
Is it possible to get replace dust covers for the Bilsteins on the rear of my mk3? I can’t see them listed anywhere
These? There are not dust covers on the rear of NC like the fronts have.
https://www.mx5parts.co.uk/rear-coil-spring-mounting-rubber-mk3-35-p-4206.html
I will have to take another look. Not sure if thats what they look like. Either way, I can’t see an easy way of fitting them - looks like the shocks need dropping out!
I am not familiar with the NC Mark III, however if the situation is similar to the NB, I can tell you that both on my NA and currently my 10th AE (also Bilsteins!) I use Honda MT fork covers. For the looks.
[/url]
[/quote]
Available in red, yellow, blue or green!
The guy in the motorcycle shop where I bought them 10 years ago for my NA looked astonished. A Honda MT? Apparently most of them died. But I found the covers nevertheless! If you won’t be able to source these in the UK, send me a PM and I will reply with a link from a supplier in Holland here. But…do hurry, I read the last news form your Mrs. Theresa M. And also learned that the EU will request all British from now on drive on the right end side of the road. But that’s what most of you guys already do. Don’t you?
Yes, you have to effectively take the springs off.
Bugger! Wonder if I can get a split gaitor of some sort that can be glued on the seam
Not sure on the diameter or length but there’s some large split steering rack boots out there and some good glues.
