MK3 ECU Remapped
I
have just had my MK3 ECU remapped successfully by Gareth Jenkins of Map Tech in
Lincolnshire. The car is markedly smoother to drive and accelerates better
without much of a step through the rev range. Power gains are reckoned to be in
the region of 10 to 13% with a 10% improvement in torque and improvements in
economy.
So,
despite what has been said for a long time it is possible to get MK3 MX5’s successfully
remapped in the UK and not just the USA.
The
ECU has to be removed from the car to do the work as the ECU has to be opened
up to do the re map. I sent my ECU to Gareth special delivery on a Tuesday and
received it back on the Friday; it would have been the day before if the post
had been delivered on time….
Gareth
has successfully modified other MK3 MX5’s and has professional equipment to do
the work, which is backed up by the equipment manufacturer. They have many maps
for many different vehicles available
The
ECU is easy to remove from the car, just take your time, outline instructions
are below.<o:p></o:p>
This
is a really worthwhile modification with good gains for not a great deal of
money. Gareth can be contacted on 07837 827499 or gareth@map-tech.co.uk
or see the web site at: - http://www.map-tech.co.uk<o:p></o:p>
Note:
The ECU is located at the front of the car under the air filter box<o:p></o:p>
Remover the battery negative terminal (N.B. make sure you know your
radio code, if your radio is coded prior to doing this!)<o:p></o:p>
Remove the electrical connector on the tube coming out of the air
Loosen the round connector joining the air box lid to the same tube as
above<o:p></o:p>
Unclip and remove the air box lid and the air filter<o:p></o:p> ·
Undo the two nuts at the front of the remaining part of the air box and
remove the airbox, there is a push fit connector on the bottom of the air box,
so the air box needs to be pulled gently to detach this<o:p></o:p>
You can now see the ECU inside a metal bracket arrangement with a
coolant hose clipped to it and an electrical set of cables also clipped to it.<o:p></o:p>
The coolant hose can be removed from its bracket and the bracket eased
out of the ECU bracket to ease/aid re-assembly<o:p></o:p>
Snip through the two cable ties holding the wires to the ECU bracket
(see note below)<o:p></o:p>
Unbolt the four or six nuts holding the ECU and ECU bracket to the car<o:p></o:p> ·
At this point you may find that the ECU bracket has two tamper proof
bolts holding the two halves of the ECU mounting bracket together, preventing
you from being able to unclip the two electrical connections to the ECU.<o:p></o:p>
If there are the two tamper proof bolts, once the bracket is unbolted
from the car, hold the two halves of the bracket and pull/bend it apart until
the ECU becomes free and access to the two connections can be gained (this is
easy and not as difficult as it sounds)<o:p></o:p>
Unclip the two electrical connections from the ECU – the ECU is now
free from the car.<o:p></o:p>
With regard to the ECU bracket you can either assemble it back with the
ECU simply by bending it back once the ECU is reinserted or drill off the top
of the tamper proof bolts. Separate the two halves of the bracket, unscrew the
remaining parts of the two bolts from the bracket and replace these with two
new suitable bolts or Allen bolts
<o:p> </o:p>
Reassemble is the reverse of disassembly<o:p></o:p> ·
Make sure you have the connectors the correct way round to re fit to
the ECU, in my case they could only go on one way<o:p></o:p>
Remember as the battery has been disconnected the DSE light on the dash
will come on, with the ignition on, but the engine off, turn the steering all
the way to the right, then all the way to the left, the light will go out.<o:p></o:p>
With regard to the cable ties that have been cut, cut the remainder of
the cable tie off the push fit bracket it attaches to. The remaining bracket
will have a loop left on it through which you can tread a new cable tie to use
in place of the old one
I bet that extra day’s wait was a bitch!!!
What sort of cost for this?
I e mailed Gareth this morning - the normal price for this work is around £285, he is happy to do it for £220 for a few more MX5oc members - just mention being a member of the club.
Hope this helps you
Thanks, would be interested to hear more about your experience a few weeks in. Cool
I’d be interested to see how this goes. I’m convinced the way forward is an aftermarket ECU, which is why I will be attempting to get a megasquirt ECU installed on the mk3 over the winter.
I would hazard a guess that a replacement chip is installed in the ECU which is programmable (where the original is not). Then some clever kid has managed to decode what is on the original chip and work out the fuel and ignition tables in the code to make changes.
The megasquirt i will be trying will bypass the original ecu for all things fuel and ignition, leaving the original ecu in place to take care of the basics like idle control.
The benefit of this is that the megasquirt will allow mapping up to 4 bar of boost which the standard ECU certainly would not.
The process uses Alientech K-Tag equipement as used by Quantum Tuning - who have a number of agents across the UK - http://www.quantumtuning.co.uk/ so the technology is available at a lot of places through the UK now
The MX5 is listed on their site and you can see the potentail gains, I asked monster sport in Milton Keynes about this as well as they use the same equipement - the answer was power up to 173bhp and torque 200Nm - not huge gains I know but for the price worth while, the price offered by Map Tech was much much better than elsewhere. Also the power seems smoother, more linear.
As I said above the ECU is opened up, connections made to it, to use map techs words: -
To remap the Denso ecu the ecu needs to be removed from the car and opened up
and direct connection made to the circuit board to first read the ecu and then a
different set of direct connections to programme the modified mapping to the ecu
I have got pictures of this from Gareth at Map Tech - but I haven’t got the brian power to put them on this site, I can email them to anyone who may be interested
 Autotronix Developments can now offer full custom remapping for all mk3 MX5"s.
The ecu can stay in place as the software allows complete controll of all ecu parrameters though the obd diagnostic port.
