The heater in the front O2 sensor appears faulty and you probably require a new one like this.
https://www.mx5parts.co.uk/oxygen-sensor-aftermarket-front-mk3-35-p-2049.html
Advice as above.
You have done the right thing, trying a reset as a remote possibility it was a one-off.
The sensor is screwed in to the exhaust manifold before the maniverter catalytic converter.
It is worth checking the wiring and loom connection but usually the only solution is replacement.
This is the precat lambda sensor that regulates the fuel/air mixture so replace at the first opportunity.
Two of the sensor wires feed the heater circuit on the sensor. Heater required to facilitate the sensor working properly, particularly from cold.
Many thanks for the replies guys, appreciated.
I have ordered a socket to remove the sensor,
because the car hadn’t been driven much and not always run up to full temperature would this be a contributing factor why this sensor may have failed or is it just one of things that fail at random?
is it worth while trying to clean it all?
Assuming the wiring and connectors good and undamaged, the sensor heater has failed.
This is very common on lambda sensors and nothing to be done except replacement.
Cleaning lambda sensors under any circumstances is very unlikely to make any difference.
Just thought I would ask about cleaning it since it hasnt had proper drive. My original thoughts to why light was on was because battery voltage may have been a bit low on start up and being only start stopped for the last few months causing sensor to get fowled up.
So if it needs a replacement sensor which brand to buy and which to avoid? I done a search earlier on Miata.net and there was a comment saying the Mazda sensors are made by Denso, should I try a source one of these?
Many thanks.
Get a new bottle of plusgas.
Spray on the sensor joint where is is screwed into the cat and leave overnight.
If you get the sensor to move say an 1/8th turn spray the joint again and leave 20 minutes.
It you have to do this say 5 times well that is the way to get it out.
You do not want to strip the thread in the manifold/cat.
Many thanks for the tip,
i have a sensor socket ordered but will do the prep work maybe tomorrow, will look into the plusgas, have similiar sprays here one of which my dad used to use for removing stubborn bolts on trains, rustflash think its called, wd40 and some other 40+ spray.
Never having changed one of these before is it ok or advised to put some copper grease on the threads on reassembly?
Hi again,
Here is an explanatory video…
Basically resistance is required to produce heat - no resistance/open circuit = no heat.
You are going to have to bite the bullet on this one Andrew and replace the sensor
Many thanks for the link, that helps a lot.
Neighbour is going to call in later with his multimeter to test, looks like we are heading for a new sensor.
Any preferred brands or go with mx5 parts item?
I have some experience of lambda sensors and associated exhaust systems.
will spend a bit of time trying tracking down a cheap replacement and PM you later.
The main issue here is getting the old sensor out without damage to the manifold lambda boss threads. Take Eddie(Drumtochty’s) advice for the best chance of clean removal. I understand you are going to use a specific Lambda socket - good move.
When refitting the new lambda, it should be supplied with anti-seize grease on the threads, so future removal perhaps less of a problem than it might be. Given the likely mileage and age of car I seriously doubt this will be an issue for you.
When mine packed up, same error code as you have, I chickened out of doing it myself as so many people told me how difficult they can be to remove. I have a trusted garage and let them do it. They charged £150 for the sensor and a half hours labour to fit it. I think the sensor is a Denso but couldn’t say for sure.
Ian
Many thanks for your help, greatly appreciated, I don’t mind spending money on a brand that is a bit more expensive if it’s more reliable, from what I can gather a genuine Mazda one is around £400, can’t afford that, was also told it’s a Denso part but not sure on this.
well it’s a lesson for me on how these sensors work.
ADL/BLUEPRINT Do a oxygen sensors for your car as well has a seperate thread chaser
Also a company call Cambiare(a rebranding firm)sell them which you could get through most major motor factors… Andrew Page,Euro,GSF etc…
checked the sensor this afternoon & found an open circuit, needs sensor
Rhino, sent you a PM
Quick note regarding upstream sensor removal and fitting :
When replacing the exhaust manifold on my Mk3.5 last month I was very vigilant about nit damaging the sensor so attempted to unscrew it while the manifold was still bolted to the head to avoid it being knocked when maneuvering out the manifold. To my astonishment the sensor was only hand tight! This car was oem with full mazda service history and no mention of work being done on the sensor.
Also the new sensor will probably have anti seize already applied to the thread with a little removable sleeve and a leaflet saying don’t get any of it on the sensor itself.
Wish mine was only hand tight,
Quick update, have new sensor, socket for sensor, lots of spray oil and can’t get the old one to slacken, have tried with engine hot and engine cold, cut wires on old sensor and used a deep socket with half inch drive breaker bar and still nothing, I have a truck mechanic friend who is gong to call and have a look and will see what happens.
Have other things in life to concentrate on at the moment so bonnet will be left closed over the weekend.
Sorted, all fixed.
We managed to get old sensor out eventually, threads where ok just was very tight, new sensor fitted with some copper grease on threads, cleared codes, and all now seems good now.
