Hello I’m after a pair of headlight lens for my mk3 2007. Tried a refurb kit. Not working. Thanks
Hi
Try here, lots to choose from.
I know nothing of the quality, and you need to bake your lights to get the lens off.
Look into new adhesive also.
I have refurbished my lenses by wet sanding up to 2000 grit then spraying with a UV stable lacquer.
The results are OK, but they will need a good buff, when I get round to it.
Have you tried wet flatting them and working your way through the grades to get the lens back to good plastic before cutting? The refurb kits sometimes aren’t aggressive enough to cut through years of sun damage. Otherwise the only way to fix it properly is new headlamp units which is £££
