Mk3 icon
Hi,I have a 2007 Icon 2.0i. Runs well,just when stopped at traffic lights etc, the idling hand drops(as it should)it then feels like the engine is going to cut out,but the the idling indicator moves up to its set position.is this normal or does something need tweaking as so the idling indicator does not drop that far to begin with.Cheers.PS it only started after fitting new battery.
I’ll be interested to see any replies to this query as strangely enough my son told me just today that he is having exactly the same issue in his 2007 mk 3 2ltr too.
OP…if I may suggest, it may help to attract interest by renaming your post to reflect what you are asking,  ie ‘2007 2ltr Mk3 idling issue’ or similar?
Disconnecting the battery is the issue here and the car has to reset the idle.
Take it on a run for 30 minutes or so on different roads with different limits and all should be fine.
thanks for reply to this thread ninja 59.  Does this mean you need to disconnect and reconnect the battery then take it for a drive at differing speeds to reset it? Just want to be sure I understood then I can tell my son to do this accordingly
Thanks for that info.
You can also let it idle for 20 mins or so, that’ll clear it, driving it 30 miles or so is much more fun though.
