After doing some brake upgrades for a track day in the summer the garage I used, SPA MX5 Specialists in Ilkeston (highly recommended) pointed out that my brake master cylinder is leaking slightly. It manage to still survive a track evening at Donington but this is definitely something I need to get sorted. Brakes/tyres should definitely not be neglected!
I have had the car a couple of years and the bubbling around the servo has always been there. I assumed that this was from where somebody had previously spilt brake fluid when topping up in the past.
Unfortunately the master cylinder as a part is almost impossible to get hold of with no third parties selling them and a new servo and master cylinder from Mazda direct are around £350 for each item. Not a cheap bill!
Damn - thanks for the heads up about the difference guys. I will try give them people above a call to see if they happen to have any.
Luckily it’s only a weekend car and is being driven even less at the moment with winter so I will hold out for a while. Hard to justify spending so much on a part like that.
Does anybody know if it is advised to change both the servo and the brake master cylinder? As it is just the brake master cylinder leaking I assume the servo is fine?
No need to replace the servo if working OK - just swap the master cylinder over.
If you look on ebay most are sold as a complete unit so a good clean combined part to replace your faulty MS and paint damaged servo probably the way to go.
Unfortunately my gut feeling on these parts being the same was wrong as pointed out. Very difficult to get information and most part numbers quoted on ebay are off the servo unit which may have some commonality throughout the range. It appears that the 1.8 MK3 has a different master cylinder to the MK3 2.0. Later MK3.5 cars on are different again as wider pipes for the DSC.
Have a good look at your master cylinder for a part number and put it up on here. I would also look at similar age 2.0 MK3s that are being broken and get to the correct part that way.
I cannot find a seal kit from the people that I use and nothing from Mazda.
I would be of the opinion some companies that refurb master cylinders in the spares box would have seals that will fit and that could be the way to go.
