MK3 NC - Looking For Wheel Size Help/Advice
  1. My model of MX-5 is: __
  2. I’m based near: __
I’m thinking of changing my stock 17" NC wheels but I’m getting a bit confused with all the choices, not just styles/colours/weights etc but sizes also.
I want to stick with 17" and only want a subtle difference in appearance just something that sits a little wider than stock so was thinking ET45 so 10mm difference. Either sticking with a 7" rim same or probably 7.5" as there’s more choice, but then I found some wheels that were 7.25" wide which only confused matters more!
Can anyone tell me which will be stick out more between a 7.25" rim with an ET40 offset or a 7.5" rim with an ET45 offset? Also, with regard to rim widths where does the extra width sit, is it on the back/inside of the wheel or the front, or is it spread equally front and back???
Thanks in advance.
Steve.
Put your sizes in this calculator and it will show you.
It says the 7.25 @ 40 offset will stick out 1.8mm more than the 7.5 @ 45 offset
That’s brilliant cheers :+1:
This is what you need
https://www.good-win-racing.com/Mazda-Performance-Parts/MX5/Wheels-Tires.html
In the end I went with an 8x17 et42 and will run a 215/45, but my car will be lowered so the additional negative camber available will help me clear the arch lips and a light roll may be necessary but worth it for that flush look.
A friend of mine runs 7.5x17 et45 on 215/45 and it’s a decent fitment and apparently very common. I’m sure he won’t mind me sharing this pic.
Thanks for that :+1:
Sorry I posted what I thought was the best link :man_shrugging:t2:, it’s this one.
Cheers Dean
