My car has just failed the MOT, Brake Failures: RBT Park Brake Efficiency: 10%
Parking brake efficiency below requirements.
Offside Rear parking brake recording little or no effort. ** DANGEROUS**.
We tightened the adjuster next to the handbrake as tight as it would go, but it still failed. Before the MOT I had taken off the rear calipers to free them up as the car has been parked up all winter. The teeth on the adjuster on the drivers side are twisted at the end! Someone has obviously tried to force it at some point. Would this cause the handbrake to not operate properly or is this a totally seperate issue? I take it that the cog inside the caliper will have broken teeth aswell, or is it worth trying a new adjuster first?
http://www.mx5parts.co.uk/product_info.php/products_id/309
I have seen these on fleabay, seems like a good deal at £70 + £25 back for the old one. Anyone bought these before? Should I replace both sides and get new pads at the same time?
