MX 5 -2004 -UK manufacture radio code
I have to replace the battery on my MX 5 UK manufacture in 2004 and I cannot find the radio code. I am pretty sure that the radio is standard manufacture. Does anybody know whether there is a standard code and/or where I might look for it. Mazda say they want £57.00 to reset it which is as much as the battery!!
Thank you. Richard.
I believe that if you haven’t disconnected the battery yet you can input a new code without knowing the old one. It may not be coded anyway. If the battery has been disconnected and it is asking for a code try the last 4 digits of the VIN number.
As Roadie says above, if you follow that procedure it may work.
However that is only one of the master codes to try.
I’ll PM you the others
