Hi All,
I have somewhat of a mystery non starter MX5 that has evaded a few people now in diagnosing the problem.
The vehicle spec is as per the description, its a 1999 Roadster 1.8 MK2 Automatic (anniversary model I believe).
The fault, cranks like a good un but show no sign of starting what-so-ever.
Â
History:
The car is in excellent condition for its age with on 76k on the clock and has spent a great deal of its life garaged and only used in the summer months.
The previous owner had it for 8 years and it developed crank no start symptoms.
The previous owner had a local mechanic go over the car and they checked all the usual things like is fuel pump, fuel filter, relays, spark etc but this guy eventually gave up and arranged to deliver the car back to the owner when it suddenly started. The previous owner then claimed the car ran fine for the rest of the year before it was put to bed for winter. The following spring, the car re-developed its crank no start problem and its not ran ever since. They did get another mechanic out to their house who went all over the car again and also failed to diagnose the problem, his parting words were, âeverything is right the car should be ready to go but it just wonâtâ.
I ended up buying the car with a suspected immobiliser problem and only discovered all of the above since.
Â
Things I have discovered / tried below: (typed in no particular order other than how I remember them)
I traced all the CAT3 immobilisation wires and re-instated the original wiring essentially bypassing the CAT3 system. Absolutely no difference, so I suspect there was nothing wrong with the CAT3 system in the first place.
Checking the steering column, this model doesnât appear to have the ring for a factory fitted immobiliser, so can probably rule out immobilisation I think.
Despite being advised the Crank sensor has already been changed, I have replaced with a new one but symptoms are exactly the same.
I observed CAM movement from the oil cap whilst cranking.
I bought a LED ECU code check kit to use on the Mazda diagnostic plug as this car is pre ODB II and no faults were reported, just one long flash.
I have checked all fuses and they all seem to be ok inside and in the engine compartment.
A basic check of the main relay (appears to click when inserted).
I can hear a noise when I link the fuel pump connector in the diagnostic plug, but I donât hear or see the fans run when I try the same test on the fan connector! (may be relevant?). Another anomaly relating to the fans is they seem to fire up if I have the ignition on and I depress the accelerator pedal to the floor (may be relevant?).
I pretty sure the problem is no spark, I tried removing the spark plug and grounding it on the engine whilst cranking and observed no spark. The previous owner said they have a new coil pack and having removed it to check, I have no reason to doubt them because both packs on the mounting bracket look clean and Iâm fairly confident both side would not be faulty at the same time and if I was a betting man I donât believe the coil pack(s) are doing anything.
I havenât had time to revisit the car yet but my next check is to see if theres power getting to the connectors of the coil pack(s).
The only other tidbit of information I have is the previous owner also purchased a second hand ECU with identical identification numbers to the original (he was advised they had to match exactly to be interchangeable)l. This ECU makes no difference what-so-ever to the symptoms so the original one is back in place. Also, I did check the power pins on the ECU which appear to have 12v.
Â
Conclusion:
Thatâs where Iâm at, I donât think Iâve forgotten anything. You can probably tell from the list of things Iâve checked so far, Iâve done a lot of internet searching, forum reading and youtube watching, so far to no avail.Â
I have about 20 tabs open on my browser all relating to these type of MX5 issues but I donât think this car will ever run againÂ
Â
