- My model of MX-5 is: __2l nc1
- I’m based near: __Bournemouth
- I’m looking for technical help or recommendations on: __servicing
Hi, has anyone had any work done by MX5 heaven in Dorchester, or can recommend an independent around the Dorset area.
Hello, I have had work done at MX5 Heaven, they know the car and have good men who the MX5 I have a Mk2 they done my chassis rails they weren’t cheap but done a good job. Also I have bought parts from them both new and used. if you book it you can have a curtesy car (they have several different models)
Sorry I didn’t say but I live at Yeovil, so they aren’t too far away.
I used to work with a Guy who had a Mk1 & a Mk3 he used to have everything done by them servicing all maintenance and repairs he wouldn’t go anywhere else.
Hi Brian,
Many thanks for the infomation, much appreciated
Glynn
Hello Glynn,
I can’t believe that no one else gave you any information be it good or bad. Every time I have been there they have been pretty busy.
Also l forget to mention they have just done up and modified their workshop and reception area.
They have a website for new and used parts for all marks.
Brian.
Hi Brian,
It surprised me as well, at least there was nothing bad said about them. I intend to pop over and see them next week and discuss the work that I want them to undertake
Again many thanks
Glynn…
Might be a good idea to give them a ring first, in all this with social distancing and stuff at the moment.
Will do
Just seen this…here’s my thoughts. I used them for bodywork and servicing when I owned a mk2. Overall I would say they were fairly good, but not 100%. For bodywork they repaired both rear sills to a good standard, however paint work was poor and had to take car back for repaint. I also had cambelt and (leaking) camshaft front oil seal done, however the seal still leaked. I sold the car shortly after. They are knowledgeable, friendly and approachable. Importantly, I got them to regularly check the condition of the front chassis rails for me which was reassuring. No garage is perfect, so overall I would still recommend.
Thanks for the heads up, I am contemplating having the car serviced, Also wanted the gearbox and rear differential oil change (dependant on what oil they use ?
I’m not sure what oil they use, but the handbook should give the details. Worth discussing with the garage beforehand to ensure they use an appropriate oil.
Recently had a new clutch fitted, very friendly and kept me in touch with developments. Reasonably priced.Recommend them.
