I have a problem with a mishaped side window rubber seal. Any suggestions on how to solve this? I’m based in Sheffield and hopefully I’ve attached an image that shows the problem.
Kind regards
Chris
Kind regards
Chris
Remove door card and pull the seal down in to the door.Basically its too high up.Be careful not to trap your hands in the window regulator /glass etc.Seal needs to be pulled down when glass is fully up
Thanks for the advice. Next question is it a big or time consuming job? Cheers Chris
Looks like it’s this one that you need.
